Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
maybe the zinganator has run out of zing ?
Check that none of your dodgy macguyver hose connections are leaking
They all seem fine, car is boosting fine too, doesn't appear to be a leak. No one on Abottsford Road likes me very much after my test though :down:
Hahahaahahhahaha no one on Abbottsford rd likes me very much anyway ;)
I'll probs be over at basksins around 10 tonight? Too late?
The ice cream will be all melted then :down:
Bored. Finished playing with wiring diagrams.
@Ravi: We're generally gone by then bro, colon has transportation issues and I need sleep :down:
You can try your luck though, some people might hang around if there's a fair turnup
I think i just died from boredom.
Plus side work is finally going to put me through a Associate Degree in Civil Engineering
Yeah ravbat, probs a bit late. Colin has to "run ranga, run ranga, run, run, run" to make his train, which usually means I leave at the same time... being his lift and all :down:
Car is fixed. Was the hose going onto the BOV. I ditched the zip tie and went for some grip tape instead. Bit more air tight.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV ;)
Awesome. Good to hear it was nothing major. Hope we can sort Jason Phil's out as easily.
Now no one likes me in any suburb from Aspley to Mitchelton. Including the police doing 40 up a hill who honked at me as I changed lanes and went past them at 60. They didn't like me changing gears next to them... must have been the BOV :down:
lol
Isn't that like a 2 year full time course? :down:
Yep. Four years part time. Fun fun fun
I have full faith in you Tim / Steve.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
