Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
:(:):):D
BOV is wound all the way in and it still stalls.
Joyish moment today, upon inspection have found that power steering reservoir is floating free. Am missing some nuts. Oh joy of joy
so im assuming from the silence here that phil has run out of fuel on the way home? or did martin installing the solenoid correctly fix the issue?
Also, john we did not hear enough bov
pffft run out of fuel... I was just lucky it didn't wreck or explode :) . Bit over one bar ( thats what she said ) see how we go tomorrow
Would you like to borrow one of my stock BOVs? It'll get rid of your flutters like you wanted.
Yeah... pipe didn't work. Did some roadside tuning (read: ripped the cunt off) after dropping off Colin. Needs a tiny bit more tweaking tomorrow. I'll just run it as is, should be fine.
Dan = grace
Dan != Grace. Not in any way :P
i wouldn't leave the house if that was the case.....
lol
yep resetified it when i got home.
That's what she said?
Any rush for these parts Tim ? I won't be able to get them done until tuesday next week :D
No rush Phil, no rush at all.
Werd
Morning mangs scarnon ?
Morning mang.
Counting down for the weekend. Scarnon with you?
gettin` jiggy wit it
Keen for German Club on wed night? (Origin night)
Morning mangs...... how was ye olde ice creamery?
@ Jason......... I'll give you a bit over 1 bar. Also don't be held back by your pipework hahaha go to supercrap and scour through all the radiator hoses til you find something that you can cut, or will bend to suit!
I'll also have those extractors this weekend hopefully so hopefully can get done at the same time as Tims?
Also wouldn't the german club be packed for origin? I'd say any drinking establishment within Brisbane would be... especially with food :P
Dan != Grace. Not in any way :D
lol
Werd
Morning mang.
Thats good then. Should have them all done and dusted on tuesday arvo. Did you want them early or just bring them on thursday ? I've never been to the german club. Are you allowed to mention the war? :D
Keen for the bar. :P
Pffftttt couldn't be arsed. I'll just saves up some monies and get someone to fixafy it for me. I'll have to ask the fitter if he can do it at the same time. Might cost you some beers :)
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
