Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Its on page 18 of the manwell. Basically go to the menu, press down to go to "Setting", then press the left key so it says "Setting OFF". Thats how I read it anyway.
If you want to drop round this arvo I can have a quick look, I'll be changing my spark plugs though and need to get it done so I can drive to work tomorrow. Should be home by 4:30.
Extend the cabling for the AVCR? I guess so, depends how dodgy you want it :)
Winrar!
ah that off setting. I'll see how I go this arvo have a few things to do. Thanks for that. How dodgy ? Extremely :P
Hopefully have the super gauges turnout by thursday and then you can see how prettiful they are
No problems mang, just send me an sms if you are coming round so I know to expect you.
Well OK then :P
Sarp Mangs weekend of death is over. On my way to uni now only about 5 or 6 hours left on this stupid assignment and its all done. Then its only a couple of little things and exams and im done. f**kin winrar.
Martin i think the German Club closes before the origin finishes
Hmm. Thats a good point. They claim to be open till "late" and origin finishes around 10, but I have found the German clubs definition of "Late" and mine often differ greatly.
If German club falls through, are we going to try and organise something else?
I'm not keen enough to organise anything, but I am keen enough to attend :). Miso is keen for sure.
KEEN
Not for german.
Just for Miso....... never met him, and I need some fresh meat......
Have you seen Rocky four ? You know the bit where the russian comes out and say to rocky " I must break you " thats kinda like Miso, but smaller.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
