Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
kunce when can you make it?
What did we go with last time? 7?
Train arrives at Southbank at 6:30
If we get there at 1830 we can at least get a table and shiz, and one of us can run down to Buranda/Southbank to grab Colin
This works.
Or we could make the dirty pom catch a bus :)
On that note: Lift?
I might pull out, not sure yet
That's what she said.
So we doing this or not?
German club for dinner then Miso's place for game?
I still think he should walk in with his 50" tv under his arm. He'd make it look like a iPad and get away with it.
In-som-nia
Sucks to be you! Nice LEDs though.
Morning Mangs.
So whats the plan?
Rape, pillage, loot, eat some eggs, loot some more, work, pillage, pillage, origin
Something about a barrel o' rum in there too
Sarp mangs.
Sarp
Sarp.
Sarp
JOHN - you added my friend Katy on fb? Hahahahahahahaahahahahahaha how quaint, she's like, 15
Edited by mosquitocoils
Keen.
Keen.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
