Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
chillin
attn Miso: Are you replacing all your brakes mang or just the fronts? What are you doing with the old ones?
Just the fronts at the moment. Don't have any bigger calipers/rotors for the back yet.
Was thinking of selling the old set. You looking for some brakes for project alfa?
I am sure we can work something out in exchange for your assistance to fit the upgraded brakes, and maybe a upper thigh deep tissue massage
Yeah I'm thinking I might try and fit some 32 brakes to the alfa. Should stop it on a dime.
Sounds like fun :D
Sounds like fun :ermm:
Just let me know when you got time.
When we get them off, you can just keep them.
You sir, are an extremely generous bosni-serbo-croat!
I shall have to at least buy you a carton of *insert preferred beverage here*
On a similar awesome note, I just found the old rears off my car, so that will make a nice semi-matching set, assuming I can find suitable rotors for the rear....
As to time, yeah well that's the issue...
Sat morning I think I'm out, Saturday arvo is a possibility, pending what everyone else is doing.
Sunday I'm probably out - although if that's the time that suits everyone I think I can make it work.
Next weekend is good, but Dan will be away, and his expertise will be useful when doing brakes. We could try to tackle them without him but? Le mans 24 hour is on too, always fun to have something to watch while mechanicalising
Thoughts?
Jason, what still needs doing on your car? You got those boost fittings sorted yet?
Thoughts?
No probs, next sat arvo is free. Probably suits me best, as there is no footy in Bris for me to go and watch, and have no games on.
The weekend after is ok, but I am on call for work, so might have to spend a bit of time on the phone.
We can work out a carton of something, and you can assist me in drinking it.
Thoughts?
Scarnon kuntz
Car is currently burning more oil then fuel. Awesome.
Scarnon kuntz
That's excellent news, especially since the latest bp oil leak in the gulf of mexico. little baby seals are thanking you now for ridding them of excess oil.
:ermm:
One of the many services myself and my car provide.
I should get a medal for it
That sucks dude... any idea why?
Also does anyone have a rear set of shocks for a 32 GTS-T? Stock or aftermarket...
Tim can field that one :happy:
Side note :
pizza capers FTW
I may be able to get my hands on some stocker 33 ones. Would that help?
Mechanical issues fall outside my area of expertise.
Side note :
pizza capers FTW
+1
I was just after the technical terms sheesh
Jason's blown a turbo seal from his mega super infinity boosto!
Is that technical ? :happy:
That would be my guess also, but its just a guess.
The flux capacitor has deteriorated causing a feedback interference loop with the syncromesh gear ionisation device, resulting in dilution of the mechanical lubrication fluid, causing it to evaporate in the combustion chamber and/or bypass the piston sealing devices.
Define technical :thumbsup:
dont fit.
Now THAT is technical
It's like... putting too much air in a balloon... and... something bad happens!
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
