Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Pizza capers pwns Hells, its not even close IMO
+1
Hell Pizza is crap. And so is that Earth & Sea bollocks
Capers > Hells AINEC
They are different style of pizza. Hell is the best of the fatty 'fast food' style pizza, which I happen to like (as previously mentioned, I lived on it for 6 years :down:). Capers is a bit more 'gormet'. I refuse to rate one above the other, I like them both.
I remove the thumbs down as they are good pizza's
Good.
Then there's no debate at all. Pizza Capers FTW.
;) but still going to hell's pizza tonight as it's practically a drive through on way home.
Damn you. No practical Hell for me ;)
Hotties + Pizza? New destination for thursday night meets?
While good, they do not even come close to comparing to the JB buffet on offer at baskins
Sarp Mangs. Hot new graduate started today. It's awesome.
Nice. I feel we are overdue for a new hot admin trainee here actually...
picsormuthafarkinban
+1
ill see what i can do
do or do not, there is no try
I've just started my engineering course... If thats anything.
techincally I would call that something, in the same sense a bush that I drive past is also techincally something.
it's not really of interest to me, but it's something..... it's there
Give me some good music to download, mangs.
John, these are the highlight albums in my recent playlist, not sure if there's anything in there for you but at least I tried
Death cab - narrow stairs (wishy washy ambient "emo" but great)
Death cab - plans (better than above, very introspective)
Every time I die - the big dirty (screamo/metalcore)
Steve aoki - pillowface and his airplane chronicles (dirty electro/house)
Bury your dead - beauty and the breakdown (metalcore)
I get my gauges mounted up on friday
I'll mount you up
Thanks man. I'll check out the ones that aren't electrofaggotry
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
