Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
ppg = gearbox
ppi = plastic piping industries
RSL= return services league
YMHBJAIBHLN = your mum has big juggs and i banged her last night
oh getting off track here... soz
ppg = gearbox
How is ppg = gearbox ? I can understand the jugg reference however.
So in answer to your question
No. My mum doesn't have big juggs.
you are making me think of jake from two and a half men... really slow to uptake...
ppg make gearbox's and are commonly used in skylines for a drag racing application...
as this is a whoretown, nothing needs to make sence...
so if i say your mum has big juggs then thats what shes got...
My reputation proceeds me.
And no ppg isn't like juggs nor tpg. Tpg is a company selling intertrons. I bought three of them.
1. sence
1. This is how idiots spell sense, since they have no sense, they can't f**king spell it.
2. This misspelled word is also a form of since according to some idiot - English translations.
<insert any MMORPG here> chat:
Idiot: That doesn't make sence!
Me: YOU don't make sense! "SENCE" IS NOT A f**kING WORD, MORON! Sorry... IDIOT! Wait, no... too subtle... how 'bout, nub to life!?
Edited by Isola
yeh, had the same crap happen with tpg
usually they aren't too bad.
meh
we had a tpg fail this evening too, glad we were not the only ones!
Seemed to be pretty much australia wide. I was hoping for the zombie apocalypse
Truth.
THREE! I think that must have been their entire supply for a year
*Insert spelling Nazi shiz here*
I'm dissapointed in you John, you're slipping:
i am bender please insert gurder
*girder
P.S. Morning Mangs. Anyone got any steering column unis lying around?
Edited by Smity42
Sup mangs. Accidentally printed a defect report 65k pages long. oops. Cancelled it by the time it printed about 300 pages though. Small win?
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
