Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Pretty much. But we have a housing shortage right? Not at all like the USA they overbuilt and...wait a minute....
As much as I would love to see house prices have a 40% correction overnight it would pretty much cripple the economy which I guess is a bad thing. It has to happen eventually though.
apparently i costs less to buy in New York than Brisbane now...wonder how true that is? I bet its not the case.
Check on ze internets?
You'd need to know what parts of the state compare to what parts of Brisbane though. I imagine some of the stuff up north would still be pretty exy, even if the city has dropped a bit.
FYI:
L1/SP126944 26/11/07 460,000
L2/SP126944 09/01/09 450,500
L3/SP126944 02/11/08 420,000
L4/SP126944 15/08/06 370,000
L5/SP126944 26/09/06 398,000
L6/SP126944 27/07/03 311,000
L7/SP126944 17/05/07 425,000
L8/SP126944 02/05/06 365,000
Lot 2, will be your biggest problem. IMHO we're in the same markey as 07 and 08, thats where price's are back at. Go in hard with a clean contract would be my advice
Depends how you look at the stats, if they are based on average incomes then yes it is true, otherwise it’s total BS
FYI:
Cheers even 450 is ok, I will get my sister to come around and make the agent cry, that should lower the price a bit
oh yeah i forgot about the whole adjusting to salary thing
Couldn't be bothered reading the last two pages......... too much serious bizzznatch bout money and houses.
Sooooooooo I'll just leave my input as:
SOMEONE GIVE ME 11ntyHUNDREDDOLLARS SO I CAN GO TO DEFQON1 IN SYDNEY
baaaaaaaaaaaaaaaaaaaaaaaahhhhhhh
/rant
DAM BUSTER TOUR UPDATE!!
The tour will be on this weekend ( the 12th and 13th of June ). After some numbers who will attend. It will be on in the after noon after 3pm on the sunday. If no one can make it, I will wait to hear back from Graham regarding another date. Beers will need to be provided as payment, as well as to drink. If we all chip in we may even be able to have a BBQ at the dam afterward.
EDIT : Forgot to mention max numbers of eight. BUT if it is a popular day then we can organise another one
IN!
In. You fockers can pick me up on the way through?
I was saying :D this weekend ( the 12th and 13th ) I was specifying a date sheesh
You are a confusing mang.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
