Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Looks like a few newbies. shame I miss out
yet again
Nice work above and beyond thanks GaraGe31.
What are you doing in here Rangamister? Aren't you s'creaming it up ?
Martin: I left a message for the guy with the crashed GTV. I'll let you know if he gets back to me.
Tristan: Can you please have a look and see if you still have the rear speed sensor from your 32?
yeah, had planned to get out there, but ended up having a few too many drinks to drive there
instead sat on my couch and played modnation racers. whoooo :)
So i get into the office, fook all works. Server is missing. Turns out its been changed, upgraded - Who knows. When? Should be done around miday.
me - so we're all doing what until then?
Office - Well the net still works...
ROFL
I REALLY want to post this on the lowballer forum:
I'm teaching a young girl how to drive and she just can't get the hang of putting clutch in before changing gears.
It's just nature's way of telling her she should get back in the kitchen
:blush:
But I have my mod hat on and not sure if I should...
Edited by Smity42
same hey
I'm researching brake options for project alfa. I don't think the 32 brakes will work :blush:
Why is it a no go?
lol. You're a mod over there?
Why is it a no go?
Too small for the front (sounds crazy I know, but if I'm going to customise the brake setup I'm not going to do it half a*sed), too big for the rear.
Theres some 4 piston 330mm alfa brembos on ebay I'm keen on.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :blush:
I give it about 10 mins tops till I think "f*ck it" and post it anyway.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :(
Yeah needs more 355mm rotors and big 6 pots. :blush:
Link to thread and I'll post it lol
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
