Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Man this engineering stuff is hard.
Question 2
Which is the most accurate response for the following?
The monitor is:
a) the item that observes available memory.
b) the computer's visual output device
c) the component which stores data
d) the computer's central processor
:P
You've distracted me with thoughts of bewbs... :P
I'm sposed to be studifying :down:
How about i post up all the questions here and you guys can do it all for me while im asleep :D
pics of desk?
I got a picture, don't know how well it will turn out thouhg (sh*tty nokia camera phone)
will have to get it off the phone and upload it at home
:D
Sorry Tim. Have been on nights and haven't picked up your alpha bits :D
All good, whenever :P
I can only send one PM every hour or somesh*t so: Come this weekend if you can, if not we'll have to work something else out. Learn not to work weekends :down:
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
