Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
who the hell is tim
Try and keep up will ya ... sheesh
I got a picture, don't know how well it will turn out thouhg (sh*tty nokia camera phone)
will have to get it off the phone and upload it at home
All good, whenever :P
I can only send one PM every hour or somesh*t so: Come this weekend if you can, if not we'll have to work something else out. Learn not to work weekends :D
1 PM every hour ? Ghey. When I get some time off I'll let you know.
I thought working weekends was the way of the future ?
origin tonight, anything happening?
Sup mangs.
Should be a good night for sport. Origin then world cup :D Spain are on tonight they should put on a good show :P
Sup mangs.
When does England play next ?
I dunno how long it actually is, I tried to send you one and it went all fail on me so I raged up and gave it a NAZI salute
Dirty mexicans
Dear Mods,
The PM function on this forum is the worst one I've ever seen. It really does suck the balls. Is it possible to fix it or will it remain of the ghey ?
Sincerley,
Dear Mods,
Sincerley,
Not a bad draft. Should throw something in there about contracting gaids though.
Yeah but where would you put it though ?
come over and I'll show y... oh... in the letter... umm...
Dear Mods,
The PM function on this forum is the worst one I've ever seen. It really does suck the balls and I fear I may contract gaids at any point from simply looking at it. Is it possible to fix it or will it remain of the ghey ?
Sincerley,
there?
Dear Mods,
The PM function on this forum is the worst one I've ever seen. It really does suck the balls and I fear I may contract gaids at any point from simply looking at it. Is it possible to fix it or will it remain of the ghey ? If it cannot be fixed is there some sort of protection that I can use such as wellington boots or a full body condom ?
Sincerley,
there?
Yep I can see where you are going with this. I'm liking it.
Too much ?
throw in a hitler reference too, that always goes well :P
Dear Mods,
The PM function on this forum is the worst one I've ever seen. It's about as useful to us as Germany was to Poland in '41. It really does suck the balls and I fear I may contract gaids at any point from simply looking at it. Is it possible to fix it or will it remain of the ghey ? If it cannot be fixed is there some sort of protection that I can use such as wellington boots or a full body condom ?
Sincerley,
yes?
Dear Mods,
Sincerley,
Final draft ?
Dear Mods,
Sincerley hoping you eat a dick and choke on it,
Final draft ?
now final draft :P
...you send it from your account jason :D
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
