Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
What time you guys cruising? Normal 6-7ish? If it's later (like 8-830) I could maybe crusie too but I'm 99% sure that's the time you guys normally go?
6-7ish is a safe assumption b-ro
Hot rods!
mine too :D
wanna touch?
Edited by Isola
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
    • Not to mention, that the correct diagnostic approach to "electrical thing does not work" is to start with what I outlined above. You only do swaptronics for things that can't be tested really easily, like ignition coils, AFMs, etc etc. And even then you hold your breath in case the fault that possibly killed the original unit kills the swapped in unit too.
