Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I declare F-Duct drinking game a success! I am nicely munted, and that was only qualy :)
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :D
my everything hurts.
Was having a jam session at a friends girlfriends house, in the room we were in theres a pillar that runs across the ceiling and being a tall bastard and all, I have multiplied my hangover by walking into it.
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :blink:
Drinking game.
Sign me up :(
What job do you have which requires work on a sunday?
I make sure you have water coming out of your tap in a nice controlled way.
Not like that.
Like this.
I made some light progress on my project car, i cleaned the garage, then realised i can't actually do anything i wanted to do this weekend cause i need to get the guards lipped before i can put the coilovers back in. And that the coilovers need new pillowballs and heavier springs. Hopefully will sort that for next weekend thought.
This arvo i started sanding back panels and getting them ready for the primer coat.
Sounds productive. :blush:
Whats a pillowball :happy: ?
sure are, they are my upper shock mounts, also known as Spherical Bearings. I'd really like to get brand new ones but i don't know where to get them from.
In other news, only a couple days until i get awesome pints'o beer and lamb shanks!
Whats a pillowball :blush: ?
I've got two in my pants, if you'd like a demonstration?
So much win! Gonna go for the pork knuckle!
Anyone know/recommend a good detailer on the northside? Mate wants his car done inside and outside before he sells it
Always you know that :blush:
Ask Sabbai.
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
    • Probably. But keep in mind that all Joshua was saying that because of things like timing scatter, and many other related and unrelated things, tuning too aggressively should be avoided. Hence why both he and I said that fitting the cat shouldn't cause you to suddenly fall into the danger zone.
    • I’m running links ecu and an upgraded crank sensor. So I guess I have less chance of this.
    • The stock Nissan CAS gets very messy at high rpm, particularly with bigger cams/springs, and most aftermarket ECUs don't do as good a job of filtering the noise as the OEM ECU somehow manages to do. So you get "scatter" in the timing signals that can be really destructive to the ECU's knowledge of engine position. And so you can get spark firing many degrees early, leading to catastrophic detonation events.
