Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Remember I had that stupid group interview where they rewarded us with Mars bars?
Well today I have a second interview with those people. Not a group thing this time though, one on one.
(That's what she said)
my message about hotness was about the car, not about you.
It's an easy mistake to make. TBF I'm in the basement again now so no reception so no msgs :ph34r:
Sounds promising? What does the job entail?
Ahh, nice. I thought you were going to be working FOR mars bars. In which case, I demand free mars bars!
I still don't know because it's a third party company recruiting for a call center for a company that they "can't disclose the name of" *shrug*
My guess is it'll be answering phones and answering questions, but I don't know if it's for a bank or insurance company or help desk or what. It's a pretty gay way to hire people if you ask me.
If that were the case you'd have to wait until I stocked up on peanut M&Ms before you got any Mars bars.
morning spam from townsville
first day of learning how to drive a race car on a race track...
by this afternoon ill be doing 200kph in a 60 zone legally... :ph34r:
this morning first session, breakfast... no shit...
they said you cant drive or learn on an empty stomach so they have bacon and eggs for us cooked by Frostie & Whincup... :)
obviously it is a government agencies who are developing new bio weapons. You'll probably be in the call centre for them though instead of playing with all the deadly diseases and small african children.
In a 60 zone?! Where in Townsville is it? Has a track been set up on the streets a la Indy ?
Jealous. How did you score this? Is it like an upgrade over those V8 experience days?
Peanut M&Ms would be more than acceptable :ph34r:
first day of learning how to drive a taxi on a closed road...
Fixed ;)
by this afternoon ill be doing 200kph in a 60 zone legally... :D
You don't need to go to townsville to hit 200kph legally, I hit it at lakeside regularly. In the pintara no less, a real car could smash 200 at QR :yes:
they said you cant drive or learn on an empty stomach so they have bacon and eggs for us cooked by Frostie & Whincup... :O
BAHAHAHAHA thats awesome :)
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
