Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
In a 60 zone?! Where in Townsville is it? Has a track been set up on the streets a la Indy ?
Yarp... V8's are on this weekend and its a street circuit...
Jealous. How did you score this? Is it like an upgrade over those V8 experience days?
I have a Cams license and a mate of mine is a engineer for one of the top V8 teams...
He pointed me in the direction of "Prodrive" which is the company behind the FPR V8 team...
They also put allot into the aussie race cars...
Anyway my lap times in practice at QR the other month were enough to impress a few so they invited me to drive their car in Townsville...
As its my first time around this closed street circuit I have to do a full days training before driving on this track...
You don't need to go to townsville to hit 200kph legally, I hit it at lakeside regularly. In the pintara no less, a real car could smash 200 at QR :ph34r:
We are limited in the aussie racecars to 200 hence my comment...
I really have no idea how fast this track is, until this afternoon I really wont know...
QR is very different to a concrete jungle like the gold coast & townsville...
I'm not clicking that. Give me a real link or tell me where it is :ph34r:
Your loss, it's the first result
In soviet russia prostitue pays you?
Awesome, i think i'll go to russia for my next holiday
That's awesome!
That is f**kin awesome. Prodrive are pretty involved in the WRC aswell aren't they?
Morning
Keep an eye out for me mangs when trolling FS sections, I'm in the market for a good quality RB oil coiler kit with relocator
Did you want it with the thermostat on it?
And does it matter if its for a 32 or what ever?
Will keep an eye out
Found one :Dhttp://www.skylinesaustralia.com/forums/32...ut-t327701.html
sickness, good job son!
Was like oh should pm you would be better. Meh oh well
Glad I could be of assistance for once lol :D
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
