Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
12 hours of staring at a puta screen...
I finds lots of stuffs ;)
lol Yeah I've noticed. I watched the turtle thing the other day (or was that this morning :) ) and was like, what the? but then I watched this and it took it to a whole new level. ha ha
Wow, well an update;
That debriefing session was massive (4 hours)...
I thought I went alright based on how many cars I over took, however my time needs much improvement to get anywhere near the front...
I set the forth fastest lap of the day, but only did it once... I need to be more consistent to get up near the front...
Most of my laps were 3 or more seconds off the front runners, only pulled 2 laps close to the front runners consistent times...
I also torched the car pretty bad apparently, tires wreaked, steering arm bent, rev'ed the engine way too hard and was un-kind on the brakes...
Today shows me that racing is not all about smashing every bit of HP out but more about technique and driving lines...
As I said I have much to learn... Driving into those blind corners is scary, very scary actually...
All you see is a concrete wall and you know what the corn looks like on the other side but then there is 6 or 7 other cars around you...
Popping exhausts & skidding the wheels under brakes across the shiny surface...
Its hard work too, my arms, hips & neck are so sore... The experience is priceless and im loving it but its taken more than I expected...
Aussie race cars were described to me as a fast go-kart, im yet to put words together that describes it accurately...
PS> Having a ball tho :wub:
So how does a general smo ( i.e me ) get to have a crack at what your doing ?
With about 70k for a season...
Or get sponsorship and make someone else pay the 70k per season...
I got a ride at QR through a mate, they liked my lap times and were desperate for a driver for two rounds this season... My story i a bit different...
I will most likely never drive again after this weekend, it was more about right place right time for me...
The regular driver will be back next round to take his spot back... :wub:
PS> Having a ball tho :laugh:
The regular driver will be back next round to take his spot back... :laugh:
That sounds so awesome. Any video footage? So this is proper door to door stuff right? Are the cars a step below V8 supercars or same regs n specs?
Scarnon mangs?
Windscreen chips getting fixed today. Indicator canceller is fixed and the rest of the S13 stuff might be in by this arvo :laugh:
They are a half scale car powered by a motorcycle engine and transmission (geared to the changes)...
Yes its door to door racing, more touch's than the utes most sessions...
Its tight and particularly scary in a concrete jungle...
It has become very popular with up to 40 cars on track at once, it costs a 1/10 what a supercar costs to own and run...
Here is video from clipsal 500 eariler in the year...
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
