Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I'm going to grab the 30e next week. Dad and I will be taking the engine out tomorrow and Sunday. Back on the road by week after next?
need a hand tomorrow?
give me a shout.
Protip: engine + box out together is by far the easiest way. Then bolt box to new engine and engine + box back in together as well
I can't come help today as I have to wait for the mobile thread repair dude. Tomorrow I might be able to
If you end up with a spare set of engine mounts - shotgun
I'm just there to get in the way
That's what she said
Anyone knows if you'll need different spray paint for plastic???
You need to use plastic primer
Opinions ppl?
or something a little more Michael Westen-ish
I like these ones but they don't come with a black iridium lense :)
Opinions ppl?
I like these ones but they don't come with a black iridium lense ;)
Either of these get my vote. My last set of Oakleys got stolen from work :P
1. Martin - get the third pair from the top. The first ones wire frame ones.
2. Green Lantern FAIL:
This is what the costume is SUPPOSED to look like for the particular Green Lantern that Reynolds is playing:
Side note :
A friend of mine is getting fired today she was trying to set me up with her friend on facebook (during a working day apparently) she mentioned she has large bewbs. The IT section logged it as porn and now she's getting canned.
LOL
Side note :
LOL
f**king lolacaust
2 x $300 + postage $52.67 + admin fees $104.40 + special cleaning cloth $7.28 = $764.35 Total.
But what if I winked at you thusly
What would that get me ?
f**king lolacaust
She's asking me what to do. I'm like nothing you can do. I did however suggest that since she is getting fired today that she should get her t_ts out on cam for me.
+ winking surchage of $14.58 = $778.93 total.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
