Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
How's that for a tat ? I think it's pretty cool
I saw an RACQ man at yatala on monday who had that exact tat! looks pretty good in real life too
Morning all!
Where do you go boxing ?
usually out at uq
or sometimes spar out at my brother in law's, if i can find somebody heavy enough
brother in law is 58kg, so no good, and brother is 96kg, so still 20kg too light
