Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Three things that happened today
1. Saw a mailbox that was a bender
2. Epic camber on hand made go kart.
3. Go kart :D 2 stroke 500cc motor, chain drive (sprocket is welded to the rear diff :thumbsup:), no shocks, 1 gear back five forward, one disc brake to stop it (also welded to the rear diff) Going to be a very dangerous bit of kit.
Didn't have my phone on me all day so didn't get ur message till like 5:30. Yeah will have a go at getting the spigot out tomorrow. Ordered an Excedy button clutch from kudos :thumbsup:
Ahh, nothing like watching Sweeney Todd and reflecting on humanity :ninja:
There's a hole in the world like a great black pit, / And the vermin of the world inhabit it, / And its morals aren't worth what a pig could spit, / And it goes by the name of London.
