Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Any of you gang bangers doing exciting shit this weekend
Was thinking about trying to fix the Daewoo... kinda not in the mood though...
Anyone going to tas's workshop? gonna head there soon to check it out.
Why? What's happening there?
well hey, if you want to buy me a line so I can drive that to meets instead of the Daewoo that'd be awesomepossum. If not, guess I'll have to keep waiting until I can get one, and be one of those... whatdayacallem?... enthusiasts?
Bringing a Daewoo is about as lame as me driving my Volvo to meets.. Oh wait. I did :happy:
I kid I kid.
and u let it hit the limiter lol!
<3 John
its all jokes breh
yea its true everyone here pussies.. watch them talk it up pretending not to be :mad:
brandon came and left cause his a bitch.. as i ahd a customer waiting so i couldnt really chat :happy:
You know im kidding right.
Buy my shit box. $7k
I said BUY me one.. not SELL me one... slag :happy:
Hey John where do you live?
around the corner from Taz's workshop
why does my clutch pedal squeak?
if being srs, oil the hinge
Edited by Isola
Dodgy bracket, flex, dry spring.
My old car did it bad + flex, welded it up perfect! Current car does, but no flex, read on here a few times just load it up with WD40 etc and it should help
yeah i will give it some WD love tomorrow, then finish bleeding the brakes and i can drive it again :happy:
booked in for an epic expensive wheel alignment on thursday (getting the rear control arms bent to adjust camber)
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
