Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
oh, we're not going to get into that argument again are we?
speed = rpm x gear ratio x diff ratio x circumference of wheel.
Engine size is irrellevant (unless a different diff ratio is driven by the engine size)
You should know that, what with your cert 2 in mechanicalisation and all :whistling:
P.S. Do you have DS9 or NG?
was wondering if you'd pick up on that :whistling: thought that thread might have been a bit old
Don't have either B-ro.
thanks for the info kids! Was trying to compare some dyno sheets, it confirms my assumptions!
car to elaborate. i love assumptions. i assume a whole lot of crap each day. i have to. i live near inala
my assumption off the top of my head was that i was doing 80 at 2800 rpm and that each 400 rpm = 10km/hour
Im doing it to compare my hp vs speed dyno graph to another guys kw vs rpm graph, I had it all finished then i forgot to save it.
Do they deal with IT stuff? Cause thats me!
We have associates that deal with IT.
I shall pm you my work number and we can go from there.
How is everyone?
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
