Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I read the first sentence and was thinking "cool! something to do!"
then I read the second sentence and thought "oh... yeah... that'd probably help"
so I'm no good to you, sorry!
It's a two man job so if I can't find anyone usefull you might have to do :(
yeah i've already done it with one of them.
They are good for flushing, and do an OK job at bleeding, but I have found (particularly when the lines have been empty, like mine were) that you need to do a quick manual bleed afterwards to get a good pedal feel. Normally my mate who is a mechanic does it and I just pump the pedal, but he has flown off to NZ for two weeks :(
Yea... I doubt I'll wash my car there again. The soap will take away the wax/polish. I'm sticking with the gentler shampoo I've got now. =D
Colin: You should try the Mother's reflective coating. Damn good in terms of look and feel/touch!
side note..
Did anyone know the new auto text they put in
some reason i type c u n t - flamin mongrel
still lacks that extra 20rwkw ?
Edited by Redsuns88
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
