Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
f**king winrar.
Dear UDB316 Students,
I refer to my email on this Monday regarding the extension of deadline for Assignment 2, we consider a large number of students will be away during next week mid-term break, and also some of you have technical issues encountered in regard to the use of CostX, we decided to further extend the submission date for Assignment 2: Cost Plan (Part 2 – Final Cost Plan Report) (30% weighting) for one more week. The revised deadline for Assignment 2 submission is now the 8th October 2010 (Friday). Please ensure you submit your assignment by the due date to avoid incurring any penalties for late work.
We are currently finalising the marking of Assignment 1, and you can get your marked Assignment 1 from Assignment Minder around 5th or 6th October. We are sorry for the delay but please understand that it really takes us a while to complete marking for 150 reports and files.
Thanks
Regards,
Johnny
UDB316 Unit Coordinator
Original due date was today lol.
you know that instead of going to icecream you could go to say a strip club and see boobs, then we wouldnt need this conversation about fully clothed teens that do nothing exciting but stand behind a counter and show no interest in our goings on...just saying :rofl:
In other news I was on my way to work this morning and forgot I was in RWD when accelerating in a hurry to pass some deadshit doing 20, nearly f**king crapped my self when it started fishtailing down the road, at least i woke me up i guess!
would they let you eat ice cream at said club ?
you know that instead of going to icecream you could go to say a strip club and see boobs, then we wouldnt need this conversation about fully clothed teens that do nothing exciting but stand behind a counter and show no interest in our goings on...just saying :D
31 owners Andy...cover charges are expensive :rofl:
lol. What kind of awd controller have you got? Is it a fancy one or just an on off switch?
imo. The display of green certainly bumps Grace 1 up but if all was equal I think Grace 2 wins.
It's a close call to be sure, but for me Grace 1 by a micron.
I seem to be in the minority here but that's OK - it means I get her all to myself.
you know that instead of going to icecream you could go to say a strip club and see boobs, then we wouldnt need this conversation about fully clothed teens that do nothing exciting but stand behind a counter and show no interest in our goings on...just saying :thumbsup:
I am dissapoint.
lol
Also those girls are all over 18 :D. Wait... what?
and people say I'm a Grinch
:D
Grace 1 wins by a MILLION not a measly micron!!!
First it's the removal of the Advans... now this :rofl:
You're dead to me.
yeah for sure
Just on off at this stage
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
