Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
Morning Mangs,
Martin's school of fixing sh*t, lesson 1:
1. unplug everything.
2. Spray with contact cleaner.
3. Plug everything back in.
4. ???
5. Profit.
The above technique applies to many things: cars, computers, plasma TVs, etc.
Stomped hard on the brakes lots on the way to work, car doesnt seem to be cutting out any more. Also my speedo seems to have come good as well :/.
fark i hate mondays.
how was sundays racing?
Meh, broke sh*t, didn't get many laps in, and got sunburnt. Sh*t happens.
haha nice mang. What do you normally run around there?
64.3ish is my best. I'm sure the car is capable of more, I just haven't been able to string a lap together. This year in particular seems to be conspiring against me.
anyone know the diameter of 32 GTR standard front pipes? Guy is selling a set on her for $150 but they are twin 63mm pipes into a 75mm collector. Just wondering whether it's worth the trouble. Still $150 is not bad. I think the HKS ones are 70mm to 80 or 85mm collector.
was pretty heavy at 3. I could see about 4 feet.
didn't even know there was a storm. spent all day in the office. was kinda surprised when i saw it was wet outside when i finished at 5
2.5inch twins into 2.95inch
VS.
2.75inch twins into 3.15inch (or 3.35inch)
Consider that they need to flow enough for 1.3ltrs each. Or to break it down further, only enough power for up to 150kw each. Easily doable with 2.5" crush bent exhaust, I made 170kw atw in my old 626 wagon with 2.5" crush bent system.
What size cat and exhaust are you running? 3"?
VS.
Compliance cat and 3inch catback. I think I'll grab em. Low ball ftw.
Morning Mangs,
Futsal was a great success even though we lost :wub: Tristan and Dan dogged us so we only had 5 players. We ended up losing 8 - 7 but it could of gone either way at the end. I scored 4 :)
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
