Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
If anyone is looking for work I recommend asking Tony or Hays Recruitment. Tony put me onto these guys, signed up yesterday applied for a few jobs and got a call first thing this morning. Oh well fingers crossed. Downside is working in the city although that means less petrol, less k's on the coon and more money towards the next car.
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :P ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Which way should it be turned? Clockwise or anticlockwise? I've been trying both in spurts but I'd like to be sure of one direction and just smash all my weight into it
Congratz mate!
Great to hear that Hays was able to help you out.
If anyone did want to see if I could pull a few strings to get them something then just PM me.
Keaton should have my email as well, so you could just grab it off him if he doesn't mind. :P
Was it a temp or perm role?
Congratz again!!
Nice score col. Now hurry up and buy a GTS-R and sell me the exhaust manifold and heatsheild from the RB20DET-R
Currentyl considering buying an GTS-X with a RB20DET-R in it.... tis a fine looking machine.
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :( ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Have you tried kicking it ?
Evening chaps
Anyone know much about hubs? Specifically I have to replace some wheel studs on my rear left wheel (33 GTST), the sucker won't move (much like when Dan came and helped with the Laser :) ) and I've thrown everything I can at it...breaker bars, impact wrench, air ratchet... nothing.
Hey guys, whats been happening?
Mate the wheel studs are a press fit so you need to push them out not twist them. Have seen it done with a hammer but this isn't the best way because the hits also smash the axle bearing and can cause it to get flat spots on the rollers leading to failure. If your going to do it this way then you should put a nut just on the stud to stop it from mushrooming. The other way you can do it is to use a ball joint remover although have never used one for this. Acording to the manual you can't remove the hub. Unsure as to why but. To reinstall space it out with washers and tighten with a nut to pull it back in. You'll have to remove the disk and pads to do this as well.
Hope this helps mate
By the way has anyone seen a 32 gtr box forsale around in brissy? Mine split a seal and dumped all the oil and now i've lost 4th syncro and probably cooked it :( Just after a secondhand one at the moment. Pm if you know where one is thanks :)
Cheers Matt
Reel big fish?
are awesome
side note am going to attempt this ;
iCrap 3000
should result in possible awesomeness or epic failure hopefully with lots of fire. Either way
win :(
are awesome
iCrap 3000
win :(
Lol i just opened that up and got no idea what that means or what it gives you. Mind you I'm just a mechanic so not really good at that stuff :)
are awesome
iCrap 3000
win :(
I approve of this plan as it will hopefully result in one less iPhail in the world :)
are awesome
iCrap 3000
win :(
This should be interesting.
My iPhone has turned to crap after the OS update.
Well, crap turning into crapper crap. Does a double negative make a positive?
In this case no
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
