Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Finally some clear weather, so got the skyline out instead of the vw.
Driving the skyline in the wet is a major pain in the ass, as the demisters are rubbish and there is no air con, so usually have to drive with the window open, getting rained on...
And that's winthout mentioning the $80 a pop, plastic rear, barely can be called, tyres
Edited by PWND
My windscreen wiper has an issue where it sometimes scrapes the windscreen, quite annoying when you're sitting in traffic, you're ipod is dead, no good cds in the car and all you can hear is metal scraping glass.
My drivers side window also doesn't go up which is awesome for surprise storms.
Don't get me started about driving in the rain lol. The 31 has no heater or A/C and 1 window is never enough to stop the windscreen from fogging up so I end up with all the windows open. My lights are shithouse normally add rain into the mix and I can see about a metre infront of the car for everything else I have to use the force. Can't see out of the back window because of shit tint left over. The wipers are f**ked and seem to readjust whenever they please so one minute they will be fine next they won't make it over to the drivers side or they overshoot it and go off the windscreen entirely.
Certainly makes driving in the rain an adventure...
My 31 is just as pleasant to drive in the rain as it is in the dry
My 32 is good too. Just not when I have to cross epic rivers. The air con demists the rear window, so it doesn't matter that the rear demister doesn't work :banana:
Lol, what an evening. Was feeling energetic this afternoon and decided to tape up the coil packs on the 33, it had a flat battery as well so I went and picked up some jumper cables from a mate and jump started the car. Went out for a drive up to the servo in warner/bray park to pump tyres up. Car just started after putting some petrol in, gave it a bit of a boot to see how the coil packs went now that we'd fixed them up, was all sunshine and roses. Until the car started hunting.
Someone forgot to tighten a hose clamp up.
Had no flat head screwdriver so we called home and got someone to bring my car out, got the car and fixed up the hose clamp. Now my bonnet doesn't open so we were trying to flag down a car. A black 32 drove past us, kept going, a multitude of other cars as well as a white stagea who did a skid around the roundabout and then got chased by an undercover car. So thanks to those two drivers for pulling over! lol. In the end a hot little p plater pulled over and we got it all going :banana:
*Stamp* APPROVED
Got this link in a email from Dad this morning lol. As good as the learn to speak Jap chick for sure.
*Stamp* APPROVED
learn to speak jap chick has nudes thus = better
I could only find shit pics that may or may not be her. I fail at internets. I demand that you share!
Question of the day - if you could swap your car for anything within reason (say 20k+ the value of your current vehicle) what would it be?
Mine? A very clean 32 GTR or 34 GTR.
My car with +20k spent on engine mods
In order of preference:
240Z fully restored + turbo L28 conversion
32GTR with a lot of work done
350Z + turbo conversion
Z32 2+0 twin turbo targa top
S2000
Bongo van
S2000
you beat me to it John
Mine is 240z, with either a rb26 or similar.
Currently in the market for a reasonable 240z shell :banana:
im actually the same as Martin, I would like another 20k to sink into mine for brakes, new suspension, track rubber, carbon bits and maybe some bigger turbos :banana:
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
