Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
now is this referring to the fact that you want to get to bnr, or is this referring to a different kind of ride, due to your carless ass being single?
:( that was gold!
.. john i have a friend named lance;
thats actually his sister, hes always keen for a guy
Just for BnR - as much as i appreciate the offer... ice cream will be the only creamy white stuff entering my mouth, thank you :O
haha nah its an xr6 turbo ute with massive balls lol
No thanks Tris, but I think that PWND guy is keen for it ;) ;) ;)
that blue steel look he is doing is making me tingle in my loins.
Martin - need some spacers :)
The spacers I have don't suit stock wheels (locating ring is bigger to suit advans). The stockers are only on there for a couple of days because she BADLY needs a wheel alignment and i dont want to wear my nice new tyres
Edited by Smity42
just saw a add on tv, some bloke reckons he has cracked the KFC recipe, what a f**khead y would u do that.
Bahhhhhhahahah
f**k some ppl are a waste of fresh air, I wonder what he planes to do with it?
No, if he does it, that's a good thing!
If two stores have the same recipe - UNDERCUTTING! KFC might finally be cheap again!
...f**k now I want KFC. you bastards.
for those of you have have it, add me on msn for christ's sake! life.after.god.isola at motherf**kin gmail dot communists
or myspace http://www.myspace.com/musicbyjohnnystorm
or facebook http://www.facebook.com/johnnystorm6126
I'M BORED!
...now i'm going to go get KFC.
*edit* no KFC for me. Can't find my wallet. Too lazy to have a hardcore search. Rissoles it is!
Edited by Isola
your retarted. kfc is one of the best fast foods known to man, and if the recipe got out, kfc might eventually go broke. :ninja::P:P
ZINGER FTW !!!
ZINGER FTW !!!
who cares if they go broke? if the recipe is out ANYONE can make it so it'll always be available.
it'll never be the same.
hold the spit, its for a cop
meh, so many of the stores are useless and screw it up and make it taste like crap anyway. I used to rake people over the coals in my store when they f**ked up. Ahhh what a shit job managing a KFC was
Martin - need some spacers :P
Dave - how the hell is that going to be on the road on September 1st?
Yeah that looks a fair way from finished
:ninja:
indians have been making fake KFC in the UK since 2001. get with it guys. they've priced it so cheap that KFC doesn't even bother to open stores near the "PFC" stores.
there's probably more PFC's in london than there are KFC's.
nigs in KFC don't sell samosa's with their 3 piece feed, that's why they be broke now.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
