Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Apparently the peak is 2:36 now, they keep changing the goal posts lol
Water didn't look high at all at 12:30... mind you i am down at Murarrie
Miso - where did you get your tartan handbrake/shifter boots from and would you care if I rocked them too?
Had them custom made. Think it cost $60 from memory. Have the details of the place that did it somewhere, if I have a look around
Have plenty of material left over at home if you want to use it.
Sink another 20k into the GTR. The depressing thing is 20k doesnt go very far lol.
Depends where and what you buy, and who you get to do the work.
20k could get you a seriously fast 32 GT-R even if you started from stock, but as you already have a fair few sweet mods it would go a LONG way.
Think about it, start with a stocker;
sell the 26 bottom end
sell the standard cooler and piping
sell the standard injectors and fuel rail
sell the standard fuel pump
sell the airflow meters
sell the standard turbos
sell the standard dumps and exhaust
sell the standard ecu.
I would think there would be a few grand in all that.
Now, doing all the work yourself you could have a built 30 bottom end under your 26 head with 4wd adapter for 7k or even less I'm sure.
now go buy 1000cc injectors, fuel rail, fuel pump(s), intercooler and pipes, -5 turbos, nice big exhaust system , ECU,boost controller. I've probably left things out but i think that would come in under 20k and you would have a 400awkw GT-R.
Mind you this would be ghetto spec modification.
Edited by Nee-san
Oh I'm sure I could make 20k stretch a fair way if I wanted and you will find some bargains along the way. The problem is then that you now have a 400kw gtr with standard brakes and suspension and I could easily eat up another 20k there lol
I'd be content with just having the gtr back on the road again. Fit the new front pipes and get decent cat and some new brake rotors n braided lines.
If you could find the details of the place for me that would be awesome. I thought they were an 'off the shelf' type of thing. If they're custom I'll see if I can track down some of my family tartan to make them out of. If not I'll find something else epic to make them out of :D
Morning Mangs,
John and Noel, you missed epic-tits-arse-legs-body redhead girl that came in for ice cream, wearing skintight black workout gear of some sort that left almost nothing to the imagination. She single handedly made up for all the fail from the rest of the night, especially when she bent over :D. Oh, and she was a P plater.
TFIF. I should be able to go home around 1:30 :)
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
