Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Lolwut?
I saw that on faceparty and approved. Then I read up some of the stuff winphone 7 doesnt do and was extremely dissapoint. Reminds me of the original iPhail :( . Hope they fix it with some updates.
I am surprised it does not work with vista though... although vista is pretty sh*t.
Vista is pretty gay. It says I need Zune to get updates and put music / movies to my winphone BUT Zune says I need service pack 3 for vista. I googled it and it looks like there isn't a service pack 3 for vista. Weird.
Side note :
Go the POMS!
Lol. Good form microsoft.
Side note :
Go the POMS!
</3
Haddin is a hack behind the stumps. Leave him in the team as a batsman and get T-Paine in to keep. Drop north.
he isnt a good enough batsman for that, would be a waste of a batting spot.
drop North Hussey and Haddin bring in Furgusen, Paine and Hughes, move Watto to middle order.
He's certainly better than north.
I'll agree with north unconditionally. He is DEFINITELY a waste of a batting spot.
No need to move Watto down, his performance as an opener is WAAAYYY better than it ever was down the order. If he starts underperfoming then consider it.
Hughes has performed at state level but i've only seen him choke in tests. No spot for him in my team.
Hussey has won test matches (and series) for us many times before. I'm prepared to leave him in for at least this series. He needs to be down the order more though, he does a great job finishing the innings.
I like Ferguson, I'll pay that.
Haddin, North, out, Ferguson, T-Paine in. Hussey down the order.
Watto is the perfect middle order batsman though, can tough it out or attack as required. At some stage we will end up back there because at the moment he isnt being used to bowl to close out innings even when on fire because they need to keep him fresh to open.
PS Having him on your highschool team was so very very helpful lol, wasnt allowed to bowl then though
A valid point. Need a genuine opener to fill the spot though, and for me it isn't Hughes.
LOL.
Speaking of watto, nice catch. First test wicket for X-Man too. Now hurry up and get the last one.
good morning gents, i just awoke
That's what she said.
Damn it didn't see that coming.....
How stupid are people ? I mean really. I requested that the caller ID be turned on so that people can see our number. The response I got was ;
"Please note, in order to access the "missed calls" feature, you will need to instruct your users to press "Directories" and then select the "Missed Calls" option.
Should you have any questions or issues relating to the service please contact the Optus Service Desk."
So we can see the calls incoming now... stupid.
Side note :
Got the zorst raised today. Was told that I could go higher if I got rid of my drager and got a 4 inch hotdog with a tri-flow cannon which are slightly smaller. Anyone heard of the tri-flow ?
i hope so....but seems unlikely
What I've seen of him so far has been good, but to be fair I didn't see any of his overs during the day today.
Are they going to have to bat this arvo or not? Nine has stopped coverage. f**kers.
he may play well for a time while he is in form, but in the fair dinkum department.....he averages close to 50 in first class with the ball, thats pie chucking in anyones language. And he is already 28 so some massive improvement isnt likely
Haven't heard of it/them, no
Martin what's your thoughts for a meet spot tonight? I'm stopping in the city to see Tristan for a bit then heading to wherever?
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
