Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
RE: GT5 - Played Dan's copy a bit on the weekend. It was good, but not sensational. I guess after 5 years I expected more...
Mainly little things. No Nurburgring. Can't change wheels on standard cars. Limitations on painting. Wouldn't let us turbo an R32 GTS25. Graphics were also not as epic as I was expecting. (Dan will chip in now and blame the fact we weren't using HDMI output but that wasn't the problem. Low polygon count, repetitive textures, lack of detail were what was dissapointing).
The racing was certainly good though so thats the main thing. I expect when I get a copy I'll get just as hooked as every other GT game despite it's fallbacks...
You have to unlock the Nurburgring, theres even an achievement if you beat the 7min 38s that the r35 did. + Theres a tutorial on how to do the whole track section by section.. havn't tried that bit yet.
Cool. It wasn't even showing up as locked in arcade mode which made me think it wasn't there. If it is there and can be unlocked, that's a point back in it's favour.
Nasty :P
just need a new plug, or is the thread on the sump ruined?
It got retapped when it was at phantom. The thread in the sump seems to be fine. The bolt they put in however... notice i said "bolt" and not "plug"? ...yeah... instead of making a new plug, or modifying one it's just some random 2 inch bolt that's actually not the right diameter. So it's been "ok" up till now. But now it's rattled itself free and the bolt thread is shagged. In the middle of modifying of plug while also ripping suspension off a falcoon and a barina... headsplode
:S
:P
Oops, looks like we can't find that page!
* Did you try to access a private track, but were not logged in? Log In or Sign Up
* Maybe the track or user has been removed
dinner check
mince, avo's, taco sauce, sour cream, CC's, onions, spring onions, mozz cheese, tomatos, torts, lettuce.....
what you reckon im making... :action-smiley-069:
MEXICAN NIGHT WOOP WOOP
Pfft mexicana monday is always a win
And yeah marty I took it off soundcloud cause one of my DJ mates tells me they like to f**k people over with copyright crap.... so I'll reupload it to another more discrete server tonight
fyp
oh yeah i put chilli in the avo's when i blended them... hot stuff...
already passed it through to the other side :whistling:
NICE ONE
http://rapidshare.com/files/433812496/Duck...__RB_Remix_.mp3 go go go gooo
Morning Mangs,
That's what she said.
NICE ONE
Cool, will d/l when I get home for much epicness.
go go go gooo
Martin's team for the 2nd Ashes:
S. Watson
S. Katich
R. Ponting
M. Clarke ©
C. Ferguson
M. Hussey (vc)
T. Paine (wk)
S. O'Keefe?
R. Harris
P. Siddle
D. Bollinger
Punter should consider himself on notice, but I'd give him a shot while not being captain to see if he can stage a comeback with less on his mind.
I thought twice about dropping Haddin after that century, but then I reminded myself that he has been a hack from day 1 and the decision was easy :D.
Spinner? I have NFI. Give this O'Keefe bloke everyone is talking about a go... or stick with X-Man. Really there is no one to choose from :).
Siddle earned his place by being the only bowler to take any wickets in the first test, although he should also consider himself on notice if he can't get any in the second innings.
Johnson needs to go back to shield games and learn how to bowl again. He's been lacklustre since the last ashes. Hilfenhouse has never really impressed me.
The selectors are also hacks though so expect the actual team to look nothing at all like that. North has no doubt 'earned' his place in the team for the next 5 years with that one wicket, and I doubt they'll drop Johnson.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
