Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
So Anna got pulled over by higway patrol, went over the car, found it was one or 2 mil low where the dump pipes come down and one of the pod filters wasnt bolted down, was going to write her up but then decided that since everything else was ship shape and these were only tiny issues he let her off....once again no mention of the epic loudness
now andy what do you think would have happend if you were driving the car......?
I think a little hammer love to the front pipes and bolt that pod down :blink:
I have been pulled over 4 times and no mention of anything, so she did worse than me lol, no hammer love for the front pipes, they are too pretty. I will just raise it 10mm, been meaning to do that so I can get out of my driveway properly anyway.
hahaha :blink:
On the subject of lowering, im going to drop some mm's out of mine on the weekend. Also will reweld my exhaust
Morning Mangs.
GT5 is awesome. While I stand by all my previous complaints, none of those things matter any more, the game is hell fun.
Component will happily do 1080i, who needs HDMI ;)
Baskins Tonight! :) :) :( Be there, or be a raging homosexual.
How much can you take out of her at the moment
About 11 inches. Wait, what?
farken flat out thursday
can't wait for the weekend, but then i am on call, so it's not much of a weekend anyway
on a side note, cage arrived, and it was the wrong one, so still looking for a r32 cage. gheyness
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
