Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Three dudes beat a stranger/homeless dude? lying on the ground, in the face with a hammer
Then they stab him repeatedly, first in the torso then in the face.
The guy stays alive for all of it, before he is finally bludgeoned to death at the end.
The three perpetrators are laughing during most of it.
I watched the first thirty secs, when the guy was smashing him with a hammer. Could not watch the rest.
That's fucked up.
I'll go to Greenslopes, yes.
Cool bananas
Edited by Smity42
Chalked a few things of my list today
1. Stalked Ravi in real life so, no need for faceparty anymore.
2. Handed in my resignation at work. Was informed that with my vast experience (18 odd months of it) that they wouldn't accept my resignation. First time that has ever happened to me most of the time they are more then happy to see me go. :)
The two are not related.... just clearing that up.
WHAT THE f**k IS THIS NEW SAU SHIT
f**k
Yeah, I'm not thrilled about it :(
just notice in your sig martin, that now you can go back to the thread where you got the initial quote from
mee sho approves
You always could!
"Less have a toast to the douche bags, lets have a toast for all the arseholes..."
Kayne Wests new project, sorta funky...
He is a bit of a weird one, not weird like Lady Gaga, but weird none the less...
Movie smashing homeless guy is not cool.
+1
New forum layout is not cool.
+1
No agreed place for Thursday night meet is not cool.
I have officially declared it SEP (Somebody Else's Problem). If someone else organises somewhere else to go, I'll go there. If not, I'll go to BR CH.
Opinions on garret t04e?
I'd wanna install it myself, it fits stock pipework yes? Never done a turbo transplant before, and wanna give it a go.
morning all. anybody else going to the hardtuned lakeside thing on Saturday?
Negative. I find the prospect of driving round Lakeside at anything other than 'balls deep' thoroughly depressing :(.
Might come out for a look-see though, depending on how early it is...
terribly shit and ancient turbo, All the lag, none of the power. I would look at a highflow will make the same power but with heaps less lag.
doh, forgot to sign Anna out
P.S. Signature Fixed :)
@ Miso, you can click the little arrow do-hicky to go back to the original post
yup, figured it out now. :P
in soviet bosnia, arrow do-hicky clicks you....
Yeah man I'm marked down for it and supposedly attending at this point, but it's dependant on workload friday arvo/night hahaha
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
