Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Any of you guys know how much fluid the 32GT-R gearbox takes ? (capacity)
Keep filling it through the gear stick hole until it comes out the plug in the side which is the fill level, which is about 3.8 litres from memory
Today was a good day at work, not much to do and i got to drive the new Alfa Romeo Gulietta 1750cc turbo, fun car in the rain
How so Lol ?
Mr. benno tried it. it fills your transfer case and not the box from memory, Unlike a gtst box. It spat it all back out through the car, Gotta love the smell of gear oil through your car.
Nah dirt isn't a problem. Car is filthy anyway and we'll be leading = no rocks flicking up at us :thumbsup:
Cool.
Yeah that sounds about right for a 25 box.
Really?? Gearboxes take THAT much??
25 box yeah, 20 box takes a fair bit less. No idea what a GTR box takes but I'd guess it'd be close to a 25 box.
I like saying box.
LOL!
HI NOEL!!!!
+1
Isn't the gear box oil shared between the transfer case, box and diff in the gtrs? That's what my driveline appears to be anyway. One filler spot, random piping going everywhere... looks like a slag of a job to do without a hoist tbh.
Dont quote me on it John but please ask a wiser head before you go ahead. It got very ugly from memory.
I did get ugly for sure, my car still reeks of transmission oil lol
There's your answer guys, this is the very car it happenned to. Cheers Bunt.
I wasn't asking so i could fill it through the top of the box (would much rather use a ratchet pump and the filler hole on the box). I was asking because if they share the same fluid, that would be why they hold heaps. can't quote properly on the new fag vesion of sau or i would have quoted ravi's question.
But anyway... whatever. Back to my little corner.
Edited by Isola
Yeah it's pretty hard :blink:
Morning mangs.... this weather is now turning to shit. Out west is just destroyed, and now it looks like storms today according to the forecasts.
It got very ugly
That's what she said.
Oh, I thought you were always that way... :P
Yeah, meant to flood ipswich today and brisbane tomorrow. Anyone live near the river?
it's getting biblical
We had it coming, humanity deserves to be wiped out.
Edited by Smity42
I live near the river, but im about 6-7 m above bank level it is expected to only go about 1m above that so im not overly worried
Expected to go 1m above bank level or 1m above your 6-7m?
when I quickly scanned through this, I read it as, "I live near the river, but im about 6'7"
I was thinking:
1. Well, at least your head will be out of the water
2. Bunta isn't that tall the stinking liar
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
