Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
yer those camera's stand out pretty easy.
The song "theres a hole in my bucket" come to mind when i have pulled my car apart. Got the drivers side cleaned up and ready for metal to be cut out and new stuff welded in, passengers side is worse. This will take all week
is it an expensive exercise ?
Hahaha no thanks
Anyone have ideas for how to make a pressure tester for my piping?
I'm thinking PVC end cap, drill small hole in side, insert bike tyre air screw part, seal around the edges and hook up to compressor.
Replace AFM with this item and listen for leaks in piping??
Will PVC withstand 10psi?
It will work, i have one that I run off my compressor. Just be careful not to over boost it though.
Less likely with a pushbike pump thaan a compressor but meh!
  • Nope 1
Please note that A J Wyllie Bridge on Gympie Road, Petrie is currently closed to traffic in both directions. An alternative route is available via Youngs Crossing Road, Petrie.
Advice has been received from Main Roads that the lower bridge may be opened late this afternoon. This will carry one lane of traffic in each direction. They have also provided advice that the high (southbound) bridge will be closed for some weeks due to extensive damage.
Weeks! FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU
Time to find an alternative route to work...
Hahahahaha sweet... Yeah haven't decided if I'll use compressor or bike pump yet.
How did you block off the throttle? I only want to pressurise from air intake -> intake plenum (but not including the plenum)
I didnt block off the throttle.I just fit my pipe at the air intake then pressurise the whole system. Just rotate your engine till you find the sopt that holds pressure and pump away willis.
  • Nope 1
Uhhh........ please explain this? :)
Drivers side is almost finished, welding in shorts and singlet is fun, except for when you get sparks and burn a couple little holes in your arm. Hopefully will have the passengers side started tomorrow so i can get the car running again before thursday night
So it seems that big thick sound proofing/ heatsheild mat that sits on the fire wall doesn't like to be welded or to be near welding. Just had a minor fire
Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya?
i lost track earlier, what turbs did you end up going with?
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
