Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I am, and I am home now. Can bring it if you want. Angle grinder on the train will be baller. Just let me know coz I don't want to bring it if you don't want it.
The old man thinks he might have one at home, so leave it for the moment. He's not home till tonight to check, and mum has no idea what she's looking for.
If he is telling me fibs, might head out your way tomorrow after work, if that's ok, as I am out at Zillmere again anyway.
Yeah no prob, will be home tomorrow arvo until i head to baskins.
Me and Jeremy are heading in now
On a side note, if anybody knows a pannel beater/spray painter, need the sunroof sealed in, as well as a front bar and my bonnet resprayed.
Oh laddergoat...
the guys at germanclub hadn't watched it before
and colin, you game-score giving away bastard, you better be up, adding and playing me at cod
Morning Mangs!
F*cking bridge is closed at petrie again (indefinitely). And youngs crossing rd too. Took me 1hr 15m to get to work :(.
Might have to start catching the train untill they fix that f*cking bridge.
hai guys :action-smiley-069:
Hai Scott! :action-smiley-069:
ECUs are on teh way from J-Land :)
Late notice german club was awesome. Pork Knuckle ftmfw.
THIS! Top job organising mang.
JASON
JASON!
Speaking of Jason...
@Phil: I was literally dragged to the german club last night mang, and then held there against my will for many hours, with many terrible beers and much disgusting food forced down my throught. As such, I did not get a chance to look at your homework yet.
The first one was the best. Second one was alright I guess :whistling:
That's what she said.
Old spice dude is awesome.
"Look down, back up, where are you? You’re on a boat with the man your man could smell like. What’s in your hand, back at me. I have it, it’s an oyster with two tickets to that thing you love. Look again, the tickets are now diamonds. Anything is possible when your man smells like Old Spice and not a lady. I’m on a horse.”
Ok, old man has delivered, so will get my angle grinder on this afternoon.
should be interesting.... ahh well, what's the worst that can happen?
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
