Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Morning Mangs,
TFIF. Wonder if I can get away with an 8 hour day today?
For Scott: Z32_ECU_Modifications_Direct_R33_Plugin V6.pdf. Booyah, V6. Please don't use the V3 one to do mine :P.
just keep a pair of baby socks in the car, fits perfectly over the gear knob and either stops it from getting hot in first place if you remember to put it on when parking, or protects your hand after the fact if you forget.
Hmmm i wonder what people would think if they walked past my car and saw my knob covered by a baby sock lol.
Very good idea but i think changing knob would be better as i never did like the one i got.
So I unhooked my wastegate actuator hose before work, went for a drive around to warm up (then a bit longer lol)
Anyway, hit around 10-12psi a few times (before backing off), but laggy, and can still hear a balloon squeak type noise.
Dump pipe on incorrectly?
Stock manifold (untouched when I replaced the turbo)
It's a split dump/front pipe, but not one of the shitty JJR ones, it's got a huge long split for the wastegate gasses. I also checked when I had it disconnected that the wastegate flapper doesn't catch on the interior of the dump (like on the JJR ones)... but that may have changed when I put it all back together..... I'm thinking maybe the gasket could be sitting shitty or something?
The wastegate is completely shut at idle.
so refresh my memory
you are getting no boost when everything is hooked up, but when you unhook the feed to the actuator you can get boost?
Probably a dumb dumb question but one I've never known the answer to
Does the diameter or length of vacuum hose make a difference? Specifically in this case intercooler piping nipple -> actuator?
Edited by mosquitocoils
Yeah I try and keep them as short as needed so that's good.... how about thicker/thinner? Any advantage?
Morning Mangs,
Success
Morn.
Stuck on a train. Plus side it's fark yeah Friday.
I'm on a trian, I'm on a muthaflipping train....
Too many knobs in that. Not my idea of a fun night out.
What turob is it? didn't you buy a highflow? It may have a balance issue....
Damnit, Nistune only posted this morning, won't get it till Monday now :(.
Still get to play with the software
Correct... Although I can still hear a squealing leak under boost
gasket or turbo is my guess.
sadface :(
This is for you.
oh and scarface.
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
