Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Sup,
Back in Brisbane for a Job interview this afternoon, then back down the coast for the rest of the week. Had the HICAS light come on while on the highway. Pulled off to get some water, light off. Back on the highway and 20 minutes later light back on....grrr! Then, just to make an absolute ass of my self at the first red light I come to in Brisbane I turn the engine off to reset the HICAS light and the damn thing wouldn't start up right away! Bloody turbo timer and kill switch and alarm causing me havoc and backing up traffic on Coro Drive.
I vote me for dumb ass of the day!
Could just need p/s fluid
I thought it was only the 32's that shared the power steering with the HICAS? Isn't it all electric in the 34?
Yeah I'm not sure, you're probably right.
I just know if I saw those symptoms in my 31, I would check the P/S fluid level :)
Hi scott, guess you didn't expect some crazy guys in an Alfa to be on the horn at you. Really need a brumby 4 speed
My parents have had 2 seagate drives fail, my mate had one that never even worked properly from the store. They had a bad(relativly) batch.
Haha! Yeah, I was thinking WTF is with this guy... Look over and see you giving me the international peace sign. Pity you weren't doing 3G......inverted. haha
do holden use the VDO headunits in the commo? you guys getting issues with the sat nav and AM reception on those units?
In news today, offically have been promoted at work to head lotus tech/senior technician, also been given a payrise.
Hahah yer scott i couldn't resist! i thought you would have been freaked out a little.
Pretty sure the brumby has broken something in the box, when you accelerate it sounds like a clicking CV, when cruising along it makes the same noise / bearing noise also but that all goes when you push the clutch in and coast along. So im thinking i'll get a good condition gearbox and a new clutch to throw in, i'll also replace the CV boots and inspect them for wear. Thoughts?
Congrats! Top stuff.
Thoughts?
Tell her to sell it for scrap metal and buy a real car instead
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
