Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
hai guys. long time, been busy being busy. Nambour, Cairns and Lismore this week. pah.
Squeally, laggy, broken stock turbo is squeally, laggy and broken. So close to this \/. Time for Hypergear.
This is like pictionary. Guess the phrase and you could win a Freddo ;)
Plz bring my ECU tomorrow :). Even if its not finished, I'll finish it off myself. Thanks :thumbsup:
Beware of ninja cats toting shurikens?
Not quite.... Was something to do with the turbo shooting a ninja star into the cat....
Ok :/ The 32pin ROM is being a PITA....
Thats what all the ladies say to you don't they...
Got it in 1 :thumbsup:
On another note, I stumbled upon this most excellent artwork.... Pushes boundries for work safe...
Can link more if needed.
You know it.
...Wait, what?
I see what you did there...
Not much point saying pushes the bondaries for work safe and then dropping the pic straight after it... link to things like that please :)
Back to Uni today... one of my two days off a week and I get to spend it surrounded by brain dead 17 year olds... Why do I do this to myself?
Also, Iced Dairy Confectionary tonight? Who's in?
Uni Hotties?
In.
Uni Hotties?
Uni hotties are all too young. Feels creepy trying to chat up a girl when she's 10-12 years younger than I am.
I'll be at BnR around 8-8:30. Having dinner with a friend first.
Speaking of Uni Hotties, the last two afternoons have been pretty fail at UQ. Was hoping for a decent turn out seeing as the temps are through the roof.
Might have to wait a couple of weeks for the new ones to settle in.
I cannot understand these words you are saying... it just doesn't make sense...
Uni hotties are fine to perv on, not so fine to try anything else. By the time I finish my degree in 2015 I'll be twice the age of most first year students.
Besides, I'm about to start work as a manager at one of the biggest pubs in town. Just as much eye candy and they aren't as young and a lot more boozed ;)
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
