Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
PWR twin pass radiator, PWR transmission cooler and Blitz return flow intercooler all being ordered. Big thanks to Dan. Won't have my baby back for a few weeks however, but such is life.
Mangs. Mondays are ghey.
Start to the week didn't help. About two hours of sleep, plus I got projectile shat on at around 2am.
Now just grinding the day out till 4pm so I can fark off home and die
For those of you registered on the other site, heres another journey in to insanity.
http://www.sauqld.com/ipb/index.php?showtopic=2992&st=0entry153843
so i take it the plan is not to sell it now?
Full ninja stealth? I must fail at detecting sarcasm today...
That may be so, but you certainly don't fail in the 'one of a kind radiator' department. 1 x custom built twin pass vertical row unit coming up!
Btw, I talked them down on price on the rad and optioned up a larger size on the cooler so same price but sick as cooling.
You also don't fail in the 'unique destruction of factory parts' department but that's a story for another bed time
Mmmmm.... Frosty cold components! Nicely done mate :) Once it's all back together and working I'll have to give the engine bay a good clean, get all that coolant off.
Here's hoping it takes them a little less time to build, but knowing my luck it will take them extra long because I'm a right special bastard!
Got your email regarding gauges as well, time for me to go hunting to see what I want there and figure out where/how they can be mounted.
I discovered something full of win today: the place I contract through offer free training and certification! I'm getting my Microsoft Certification, CEH, CCNA/P and a bunch of others including LIPC-1 figure it might come in handy one day.
    • No concern, especially not on E85 you won't really have an issue with moisture. You could put a ball valve on it and only open it when you're going to punish the car. On daily commutes you wouldn't need it open to vent the crank case. I would say it's above the oil, considering that looks like it would sit above the windage tray
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
