Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Don't break your cars anytime soon.
Nissan Motor Co said it would resume production at its Kyushu plant on Thursday and Friday for as long as inventories of parts last. Other auto-assembly plants, as well as its Yokohama engine plant, will remain closed. Nissan did not disclose the number of vehicles affected.
Nissan said transmission plants were damaged and have stopped operations because of another earthquake on Tuesday in Shizuoka, southwest of Tokyo.
Read more: http://www.news.com.au/breaking-news/japan-car-makers-still-hobbled-after-quake/story-e6frfku0-1226023375131#ixzz1GpnIZbys
what's the headcount like for this afternoon?
I should be able to manage yet another one of my brief pit stops
Will be there for a similar pitstop.
I'm in for tonight. Probably walking however :( New radiator won't be ready for another week or so and after the radiator goes in it still needs to be sent to EFI for tuning so it may be two more weeks until I have her back. At least I should have a few more killerwasps for the hive with the intercooler and new ECU and it won't go boom with the PWR radiator :)
Nice!
I fixed it!
That's my days work right there.
Good shit bru.
Good Job, Team.
Mr Motorvation right here.
Thats what she said.
THat's what she said.
I like you, Noel
That's what Marty said.
fixed
AS in Neutered?? :blink:
They don't make parts for 31s any more anyway.
Nice!
Good shit bru.
That's what she said.
I now have a nice stainless dump and front pipe for teh stag.
Dump and front pipe
Bit eBay Spec, but it'll do for $120 :D
Doesn't look too bad :thumbsup:
Got the old lady out of horsepetal today so probably a no show tonight.
That seems like good news :)
Give my regards to the girls and tell them thanks for the mamarys.
Will do.
You think I sit at my desk with clothes on...
I think you don't have a desk and this is all a ploy to make us think you are someone important!
I knew as soon as someone mentioned 'that's what she said', you'd show up lol
You're right :(
It's really just a stainless table from IKEA. Looks like something you'd cut an animal up on :shrugs: Maybe I'm Brisbanes very own Dexter.
My ears where burning... What can I say!
Not the thighs of someone rubbing on them?
LOL.
Picked up some brake pads on the way home, putting them in on sunday. One thing to cross off the list.
Edited by hylian
One of the many pics of the Japan aftermath.
Not sure what the car was, but I wouldn't mind the brakes of it.
Will have to spend some time perusing japan auctions in the upcoming months :P
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
