Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
John Q4 Brera aren't too bad, heavy and slow i think though other people have different thoughts, pretty much the engine in it is what you guys call the SIDI i think. It uses the GM global V6 bottom end with alfa's own design direct injection twin cam variator head, which holden then used.
Awesome, thanks for the info!
Was thinking of maybe looking at one, but maybe not now. SIDI engines are a terrible design from a working on it/modifying it perspective. Not much of an improvement on the Alloytech really.
Where at!...Your place ?
The late late show with Craig Ferguson, he has a robot skeleton as a side kick...
Its on the new "hello" channel at 10:30pm week night, very funny...
He says random stuff like "sex party" and "in your pants"...
[vid]
[/vid]
There's a gremlin living in the front drivers side of my car I think. Wheel bearing needed to be replaced there, the window actuator doesnt work there and doing a simple job like replacing my brake pads turned into an overnight stay due to losing a copper washer off the brake line causing fluid to go everywhere.
nice work. I say fix it enough to sell and buy a 31! haha.
Today while at indro, andy spotted me, and then i spotted twocents, he didn't see me, but i saw him coming out of the cinemas
Had a chick in tonight who was wearing a little black vest as a top. Only thing was that she didn't have it done up and had these little butterfly stickers over her nipples. So much win, especially when she was dancing at the bar ;)
Morning Mangs,
I like boobs.
Drove the 31 to work today. Much win and awesome. Must try to find time to call EFI today...
Joined SAU QLD forum and club !
Successful day !
I paid my monies but haven't heard back yet :(. Andy must be slacking...
Lowball club cruise = great success :thumbsup:
@Colin: Won't actually see you Thursday, will be in Melbourne town :D
Lowball cruise was great. Ah true mang. Definitely need to hit up the F1 next year.
Wash your colon, GTR
Yeah it's pretty filthy. Got this weekend off though so I'll wash it then.
Oh and Morning Mangs
I can ask John to put his pink bikini on and wash your car for you?
Where is young John these days? Doesn't post much anymore.
Edited by hylian
Thanks for driving me. :wub:
Missing, presumed employed.
We lost power this morning, good stuff for a power distribution company...
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
