Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
its a new colour in 2011 models
you will cream your jeans for sure when you see one in person, they are seriously beautiful...
its similar to the old R33 4 door "deep blue" colour...
Color suits the car well, that's for sure! Will yours have color matched bumpers though? Or that 90's spec grey? ...are those a pillars black? And... are they led running lights?
attention scott and colin, i won't be able to make it tomorrow night, i actually have an important meeting that i need to attend. I will organise pick up and payments later.
Scott if your in the valley tomorrow give me a bell, i pm'd you my number in faceparty
So... what's the weirdest thing people have found in a car they're doing a service on?
Today I found a dinner plate in a Barina. Just one plate. In the passenger footwell...
I've been having the worst farkin week. I read this and I lol'd like never before.
SAU can cheer a negro up.
But OT, when I was looking at XR6T's, I looked at one at a Fraud dealership, opened the bonnet and had a bit of a look around for leaks etc, when I saw my reflection down the side of the manifold with "Objects in mirror may be closer than they appear" some muppet had left a mirror in the engine bay when they were getting the engine no. Needless to say I didn't buy that car.
Sarp Mangs. Shit day is shit.
Apparently Godzilla and Heat Treatments are running at the test n tune at Willowbank on Friday night. Anyone keen to go see some 7 sec passes?
If it's a test and tune night it's free for spectators. You'll see cars running anywhere from 8 second passes to 18 second passes. All kinds of shit will be there running all kinds of times.
John, what was that tyre from? Has to be a truck of some kind... clearly?
My skyline passed it's road worthy inspection... have 2 people interested to come look over the weekend. I'm sad/happy. pinch.gif
I meant what time does it start and what time does it finish. But 8 second passes would be nice to see.
Some quick digging says that there's a top fuel drags on on friday, not a test and tune. And also that its 20 bucks for spectators at test and tunes aswell.
Edited by sneakey pete
It wasn't on anything, just sitting there. The 155/55/R13s next to it looked like doughnuts!!
Edited by Isola
Last time I went to a test and tune it was free for me to be a spectator. Maybe they are charging because the top fuel is on later?
8 second passes are fun to watch, I was more impressed by some of the real POS looking cars running 10-11 however. Also, the old Corolla with a 20C rotor in it made me happy in my pants ;)
I was gonna say... test and tunes have never been free to watch...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
