Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
what suburb are you guys in?
Who's that directed at?
Martin what phone did you get? I read a review on the first of the 4g androids the other day, apart from battery life draining in a few hours on 4g it looked pretty good
red maserati?? hardtop or soft top?
we had a 4200 GranSports yesterday and i think there was a GranSports Cabrio there too.
It was a soft top. Parked up at the rail with its bum to the street.
that would have been the cabrio, i did some work on that thing, not too bad at all, sounds nice. Engine from them will fit a skyline engine bay
Haha awesome!!!
Speaking of engines that fit into things, I need to run an idea past you at some point. Unless it's an LS engine, no one at work knows or cares.
you :P
I can see if one of our offices would take someone on for work experience
you :P
Haha, she's in Albany creek, she's public transport literate. I work in the city and travel caboolture train line so transport generally won't be a problem, unless it's in the middle of nowhere.
Morning Mangs
No ikes cream tonight. Going to support the dirty old man. Although I won't be able to vote as I'm not a member and I have no money to become a member until pay day :thumbsup:
bishes
out for agm and probably ice cream as well. shit to do, people to kill
Get pics. :thumbsup:
p.s. if theres any looting, pillaging, or raping involved gimme a call. :cheers:
    • First time, battery connected, then I went to disconnect it (thinking maybe the battery is fked). Both times, HUGE sparks went flying and shit started to glow 🥲 I'm planning to do that next, unplug the alternator. Just a bit of a pain in the arse due to the plenum and DBW, but needs to be done. Threw sparks even when I just touched the +VE jump point, even before letting go of the clamps.  Good point about the amps, there's a 8 gauge going to a fuse block that splits into 2x 12 gauge.  Going to be a fun process of elimination
    • Random thoughts, is it possible positive jumper lead was touching either that metal box, or the oil line beside it? And just double check with battery disconnected there cables/connections aren't touching/resting on car body/other conductive material. It could even be an amp cable has come lose and is shorting, however I suspect you have fuses close to the battery for amp power supply and they would have popped (though if one only have melted, it could be why you have a higher resistance to earth now and it's not popping, so I'd double check amp wires/fuses)
    • Thanks for the kind words! Feel free to ask anything, anytime. Cheers.
    • Haha thanks! Our 4 seasons here are a great motivator to get things running for the summer season.
    • When they started to glow and crazy sparks, was the battery still in the car and connected to POS and negative? What sort of battery is it? (Lithium, lead acid, etc?) Is it possible you stuffed up the jump start and managed to get both POS and neg cables on a dead short through the skyline?   Check the resistance again, then disconnect the power cable on the alternator, and then measure that same resistance from POS pole to earth. Then measure alternators POS pole to alternator body (with cable disconnected). Do the same on / with the starter motor.
