Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
How much are the Khumo's at Option 1?
Going from memory (it may be the other way round) in my sizes (215/45/17 and 235/45/17) it was something like:
595SS => F $110, R $120
KU31 => F $120, R $110
595RS-R => F $180, R $180 (on special)
Prices per tyre, plus fitting ($5-$15ea depending on if you want them balanced or not, and if they are on a car or loose wheels)
So in those sizes, the SSs and KU31s end up exactly the same price for a set of 4.
You want round phat black babys ? :O
Round phat black sticky babys :thumbsup:
Whilst the khumo might stick a tad better than the feddy SS just remember the SS will run rings around it in terms of mileage.
As an allrounder I still rate the feddy.
I'm not finding that. My last khumos lasted about a year. The SSs look like shagging out in about the same ballpark.
The SSs might have more meat left in the center when I'm done with them, but that doesn't help me if the edges are on belts :P
You're doin it wrong. :whistling:
There's nothing more I can do to reduce the camber wear on the rear. Its the nature of the datto-spec IRS. I have already spent a small fortune getting the base camber reduced as much as I can, but its still a tad over 2 degress, and it's still going to camber the f*ck up when it squats.
I could change the alignment on the fronts to make the tyres last better, but why bother when the rears wear out faster anyway? I like to keep the camber high enough to balance the rears, and I like a little toe out.
Ahem...cough cough.... GET A 33.
MWAHAHAHAHAHAHAHAHA
This could explain the stormtrooper walking down st pauls terrace with a suitcase this afternoon.
You guys should drive thongslappin' fords and holdens, you only need a good tyre on one side at the rear to get traction in the wet!
Epic night!
Ben (Homo) should get on here more often, then he would have something to do while waiting for his girlfriend to get really smashed at a work function
tears.
Very much so :(
The choice of who to but it from came down to two stores
Store A was slightly more expensive, but their website seemed more professional and they responded to emails quicker. They also guaranteed my phone would be shipped as part of their first batch of stock.
Store B was a bit cheaper, and they weren't sure how much stock they were getting in the first batch so couldn't guarantee they would have enough.
I went with Store A... Store B ended up with a truckload of stock, and worked through the public holiday and got almost all theirs shipped on tuesday. It seems most people who ordered from there's phones are in china already.
Store A has been dicking around, posting blog updates and emails on how hard their life is and how many orders they have to get through, and they hope to have them all shipped by the end of the week!
Backed the wrong horse... :(
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
