Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I have come to the conclusion that all tyre monkeys are f**king speds.
Thanks Dan for balancing my wheels up proper :thumbsup:
Sounds good :) meet you at your place at 10?
call it 11 bro. Its 5 minutes to lakeside from here, and I have a 30th to go to the night before.
Just settled in at home after a hard days work, beer in hand and bad movie to watch when *Ring ring* oh it's my phone. Answer phone, "What's that? Flying squad hitting the venue tonight? Yay, there goes my night off!" Into car, back at work now.
For those that don't know the flying squads are MAJOR audits/raids conducted by members of WHSO Qld, Dept of Fair Trading, OLGR, QPS, QFS and occasionally Dept of Employment and Dept of Immigration. Major not fun times for all involved. I have 99% of my ducks in a row, let's hope they don't go looking for number 100 :P
What/Who happened?
Ergh.. cbf typing. Short story of my most recent adventure:
- 8 tyres that need to be swapped around on rims and changed inside edge to outside
- I put masking tape on each tyre labelling what rim it should go on and what edge it was
- dude said he would need em for two hours
- left em there all day, went to pick em up after work and they weren't done
- went back the next day and got them, spoke to a different dude and apparently the reason they weren't done was coz the tyre monkey f**ked up and put the wrong tyres on the wrong rims and had to start again.
- anyway get home and a bunch of wheel weights have fallen off into the tray of the ute on the way home. A heap more have fallen off since then. Seems they didn't clean them before sticking the weights on, or bang them down on or anything...
- most of the rims had 200-300g worth of weights on them, when Dan re-balanced them today I think the most he put on one was 100g, the rest took about half that.
And I have been dicked around a few times in the past, things like tyres being put on the wrong direction, etc. Basically they are all dumb shits and should be shot.
Martin which shop was this?
This particular case was just a tyre shop right near my work. I have used em a number of times before without issue though.
Previous cases have been a number of other shops.
Driving sister to work on Saturday morning never gets any easier, freezing ma titties off
I'll drive your sister to work :thumbsup:
Meh I've been riding the bike all week lol. I've forgotten what it's like to be warm in the morning lol
I'll keep your sister warm in the morning :thumbsup:
P.S. Morning Mangs
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
