Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Too much waiting. Mongorrians must have seen a wall, they kept disappearing to do god knows what instead of cooking.
Waiting made me late for my second engagement of the night. This was a very bad thing. Apparently 20 minutes late, even when notified in advance that I'll be a little late, was too much of a wait. Flip side, I'm talking shop with Brisbanes best bartenders as they do some training. Free booze FTW! Wouldn't have been doing this if otherwise occupied ;)
was out for the night due to previous engagements. Keen for more dinners though.
Miso no worries on those rims, are you allowed to keep them? also pretty stoked to hear that they are 17x9.5 +18 not the 9 i was told.
Morning Mangs,
Although, it's not like the ribs were delivered in a particularly timely manner either... :P
German club next wednesday? Who's keen?
Keen. Although isn't that origin night?
Probably working next Wednesday night, will have to pass on German club for now. Will confirm yes or no later this week.
2 days off of work in a row now :) Very happy boy!
AAARRRGGGGGHHHH!!!! F*CK .NET not being properly thread safe. Now I need to redevelop my whole application :(. There goes months worth of work...*
*May be overdramatising slightly. However, I am pissed off*
Indeed it is. Only football match's that i watch.
Ditto. Not sure why but there is something about Origin that makes me want to watch it...
Possibly because I spent 6 years missing every match due to working at dominos?
Apparently it is. But I don't have a single f**k to give for origin so :thumbsup:
They'll probably play it on the big screen anyway. But what about the bogan crowd factor? That's the bigger worry.
You'll be ronery.
But his sister won't be ;)
I was going to go to the game and the after party for origin.....but a spanner appears to have been thrown in those works. Stupid women and thier fickle friendships. That said by next week every one may be best buds again and I will get to go
im not a fan of the football either. I normally don't watch it, that being said if we go to german club i'll come along i'd say there would be a crowd, maybe they'll have them in the hall. The will also probably do the fast menu for the night too.
fixed the issue with the rats?
All this talk on the radio about "planking" gets me thinking. Colin call shotgun on being the first to offically "plank" your sister
Sig'd
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
