Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Morning Mangs,
TFIT :)
Sig'd
Beat me too it :(
Off to Powerlink again today!
I hope Cassie is on reception for you. I haven't seen her there recently.
McFly, tell them to give me my own desk seeing as I'm there so damn much.
Pfft... they only give me half a desk in the hole under the stairs. What makes you think you deserve one?
And random question: Dan, do you know anyone that works at Volkswagen?
Nick used to work at a VW dealer in the 'swich. Not sure if he's still there.
:rofl:
That's what she said.
Work sucks.
+11ty.
Any of you mofo's play with web site building, website analytics and search engine optimization? My question relates more around whats something worth from the data shown and how does one pwne Google in the ranks
1. She won't be, but I know where she is ;)
2. Because I'm more awesome than you.
3. I mean the workshop at Newstead :( thanks though
Orly? Do tell...
I put it to you sir...
Fussy Bastard
McBites taste like McBalls.
I would totally smash the back out of Cassie. Then flip her over and smash the front out of her :wub:
Horny little devil arent you :rolleyes:
I do. come see me. not a short answer to your question.
Koya Wheels - What are they like, good / bad/ in-deferent?
I for one had a set that lasted ages and gave me no issues, a little bit heavy but probably not a big issue for you. Some people have had issues with cracks, but its a small percentage and usually on track cars
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
