Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I bozzed in my pants, I bozzed in my pants.........I opened a window and a breeze blew in.......I bozzed in my pants, I bozzed in my pants.....
bwahahahahahahaahahah :thumbsup:
getting to work this morning requird a stop and rewater, but new hose fitted and seems to be functioning finerofl.gif
must get better wheels and tyres for next time!!!!
also are there gonna be pics up somewhere?
Edited by KRECHR
@John: GPS says I was doing a max of 190 :(. I don't think I trust it.
Also, you owe us some pictures ;)
that reminds me. I should look at Boz's one once I toss the screen back in. I bet it says the same if not higher.
Don't think I got it much past 170 or so down the main straight, will be curious to see what I actually hit. Was too busy looking at the track to pay attention to my speedo.
we will know on wed morn.. (hit reset on it as well ;) )
I watched your speedo max out and the rpms keep climbing. That last run down the straight felt like 210 to me.
I found out I don't have speed limiter cut on my car after my speedo hit 180 but I doubt I hit quite as high as 200. Didn't feel as fast as the pintara.
Pictures soon bro.
Can't trust a factory speedo anything past 100. Can't trust my speedo at all, its reads about 12% high at the best of times.
I would however be surprised if I was doing less than 210 in the sprint sessions. That run I took you on, that was probably 180-190 odd.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
    • Hydro lifters not bleed up could be the ticking noise
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
