Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
There is no way I am going to go and eat icecream, outside, in single figure temps. That to me defines silly.
^^Skirt.
It hasn't even hit single digits on the big a*se thermometer there yet anyway.
So uber turbo has been paid for and will be built this week. 350hp+ atw in a sub 1100kg car.... Bring it!
I hope I can make that much in my 32 when it's finished. I picked up my block from Chiltons this morning, just gotta put it all together now and port the head. I'm hoping my 4 year old $100 225/50/16 tornados will be adequate for traction
Thats pretty exciting!
Those tyres should hold.....at idle
Morning Mangs,
TFIF.
Ikes Cream meet was good, Andy is a skirt - it only got down to 11 degrees.
Drama towards the end as 2-bob, 5-quid, and douche got reversed into in the carpark as they were leaving. :(. Hope insurance doesn't give you any trouble, let us know if you need witnesses.
Final thought: Hail to the King, baby!
WTF are you on or about on both counts Smitz ?
Count the first: On or about the 9th of June, 2011, one twocents, while driving a car owned by his girlfriend, five-quid, and with overly exciteable passanger the mighty douche on board, was struck in the front right quarter panel and drivers side door by a silver Honda CR-V who decided to reverse straight put into them. Details were swapped, quarter panel was bent to allow door to open and the mighty douche continued to dance around in excitement over his purchase of an auto loading pipe.
Count the second: After a development time longer than the time between "we will have a man on the moon by the end of the decade" and "That's one small step for man..." Duke Nukem Forever is finally coming out. Nerds everywhere have had a collective orgasim.
Seriously, Duke forever has taken longer to release than the foundation of the Apollo missions to success with Apollo 11. The Beatles formed, recorded all their albums and broke up in less time than this game has been in development. While this game has been in development multiple wars have broken out and a few have ended. Britney Spears' entire career fits inside the development window of this game. It took them less time to build the channel tunnel than this game. It better be one genre defining game is all I can say...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
