Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
What does the loom do? I though most of the time the ones in the guards were to do with headlights and indicators.
I've lost my indicators and a couple of other little bits. Headlights are still ok and rest of the car is running as per normal. Chris is sorting it out tomorrow and I got some prices on some new rubber for the fronts. Will have a look and see if I can't jack it up a little further but they look like they are at 100% as is...
All I want is a front end I trust and right now I don't trust mine as far as I can throw it :( There must be some aspect of the front suspension setup I'm overlooking, surely the change from 225/45 to 235/45 can't be the only culprit here. Its only 4.5mm difference in the sidewall or 9mm overall.
Morning Mangs,
Too quiet in here :(
That sux dude :(.
Remember 225/45 to 235/45 is going to make the tyre WIDER and TALLER. So it could make a difference.
Yeah, it is different but who'd have thought that 10mm wider and 4.5mm higher would make so much difference. Once I get the loom sorted I'm thinking I'll go buy some 225/45 595 RS-R's for the fronts and keep the 235's as spares to replace the rears I'll no doubt ruin at the drag day ;)
Question for all. If under boost my car sounds like i am strangling a cat BUT only happens when cold what would that mean? Thinking turbo on the way out but hoping that isnt the problem.
Oh and good morning all
Looks like Joe made a call to UK customs for me! :) Thanks Brooo
18-07-2011 19:45 National Hub Received and processed
18-07-2011 17:47 International Hub Forwarded for UK processing
15-07-2011 08:38 International Hub Awaiting Customs clearance
10-07-2011 17:03 International Hub Awaiting Customs clearance
10-07-2011 17:00 International Hub Received in destination country
05-07-2011 23:58 Delivery Agent - BRISBANE - PTT Forwarded for export
05-07-2011 16:21 Delivery Agent - AUSTRALIA Collected from customer
I was told 2-4 days by Aus post, and its now been 13 and it still hasn't gotten there yet :(. 8 days to clear customs :devil::domokun:
Could be a dying turbo. Could just be a gasket or something too. worth checking out.
Customs clearance number speeds that up. average ex japan for me is 3-5 and 6-8 for the UK.
If it was gasket tho wouldnt it happen all the time and not just when cold? i am really hoping it is gasket <BR>Typical tho. First time i go to a track i get issues lol Edited by Kiwibob
I had no problem getting it here from the UK. Left the UK thursday night and I got it on Monday. I don't think Aus customs had a chance to blink it went through that fast.
Hold up has been sending it BACK to the UK for warranty (f*ck ever buying a phone overseas again). But it seems I can blame Joe for the holdup :P :
Urgh, my busted phone has been sitting in UK customs for 3 days. What's up with that?
I called them and told them to do so. Had to pull some strings but it was well worth it :nyaanyaa:
If it's a gasket it might just be on its way out at the moment so as the car heats up the gasket expands and fills the holes. When its cold it's contracted and leaves a bigger hole.
average ex japan through customs for us is about 20-25 minutes...:P
haha!!
your company is a 1000 times bigger than mine..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
